wow... nen 3,6 für 29000$ netto - nicht schlecht...
Mit den Preisen (umgerechnet) in D bräuchte VW keine Absatzschwünde fürchten 8)
Vor allem die Serienausstattung:
Powertrain
Recommended fuel : premium unleaded
Emissions Type: LEV
280hp 3.6L DOHC 24 valve V-6 engine with variable valve control, variable intake length, direct gasoline injection
6 speed automatic transmission with overdrive, Tiptronic sequential sport shift, driver mode select
3.45 axle ratio
4Motion all-wheel drive
Fuel Economy City: 22mpg
Fuel Economy Highway: 31mpg
Fuel Tank Capacity: 18.5gal.
Emissions Type: LEV
3.45 axle ratio
Front-wheel drive
Suspension/Handling
Front independent strut suspension with anti-roll bar, gas-pressurized shocks
Rear independent multi-link suspension with anti-roll bar, gas-pressurized shocks
Speed-sensing electric power-assisted rack-pinion steering
Front and rear 17" x 7" silver aluminum wheels
P235/45R17.0 H BSW AS front and rear tires
Body Exterior
Driver and passenger power remote door mirrors
Turn signal indicator in mirrors
Body-colored door mirrors
Body-colored bumpers
Chrome bodyside moldings
Clearcoat paint
Clearcoat paint
Convenience
Express open/close glass moonroof
Speed control
Power windows with driver and passenger 1-touch down/up (operable from the driver seat only)
Remote power door locks with 2 stage unlock and illuminated entry
Manual tilt/telescopic steering wheel
Day-night rearview mirror
Front and rear cupholders
Dual visor vanity mirrors
Full floor console
Driver and passenger door bins
Rear door bins
Manual air conditioning
Speed control
Full floor console
Rear door bins
Seats and Trim
Seating capacity of 5
Front bucket seats
6-way (2-way power) driver seat adjustment
Power 4-way driver lumbar support
6-way passenger seat adjustment
Manual passenger lumbar support
Center front armrest
60-40 folding rear bench seat
Metal-look instrument panel insert
Metal-look console insert
Front bucket seats
Entertainment Features
AM/FM stereo radio
6-disc CD changer in-dash mounted
MP3 player
8 speakers
Window grid antenna
AM/FM stereo radio
MP3 player
8 speakers
Window grid antenna
Lighting, Visibility and Instrumentation
Halogen projector beam headlights
Variable intermittent front windshield wipers
Speed sensitive wipers
Rear window defroster
Front and rear reading lights
Light tinted windows
Tachometer
Outside temperature display
Low tire pressure warning
Trip computer
Trip odometer
Tachometer
Trip computer
Safety and Security
4-wheel ABS brakes
Brake assist
4-wheel disc brakes
Stability control
ABS and driveline traction control
Dual front impact airbags
Dual seat mounted side impact airbags
Side Curtain Protectionâ„¢ overhead airbags
Airbag occupancy sensor
Power remote door locks with 2 stage unlock and panic alarm
Security system with Immobilizer III ignition disable
Manually adjustable front head restraints with tilt, anti-whiplash
3 manually adjustable rear head restraints with tilt
4-wheel ABS brakes
Brake assist
4-wheel disc brakes
Stability control
Specs and Dimensions
Engine displacement: 3.6L
Engine horsepower: 280hp @ 6,200RPM
Engine torque: 265 lb.-ft. @ 2,750RPM
Curb weight: 1,737kg (3,829lbs)
Front legroom: 1,051.6mm (41.4")
Rear legroom: 957.6mm (37.7")
Front headroom: 975.4mm (38.4")
Rear headroom: 960.1mm (37.8")
Front shoulder room: 1,414.8mm (55.7")
Rear shoulder room: 1,386.8mm (54.6")
Passenger volume: 2,727 L (96.3 cu.ft.)
Exterior length: 4,780.3mm (188.2")
Exterior body width: 1,821.2mm (71.7")
Exterior height: 1,473.2mm (58.0")
Wheelbase: 2,710.2mm (106.7")
Turning radius: 5.5m (17.9')
Curb weight: 1,622kg (3,576lbs)
Turning radius: 5.5m (17.9') :?:
Dann noch n paar Extras (Xenon, Sportpaket, ALUs) und man hat sagenhafte 35000$ also knappe 29800 EUR netto bzw 33640 EUR brutto
Für DEN Preis nehm ich einen, der ist ja fast günstiger als mein 1,9 TDI in 2002 :evil:
