Habe jetzt eine LOG Fahrt gemacht, komme bloss hier noch nicht richtig klar.
wie ich das hier Hoch Laden kann
-- 11.12.2011 - 13:25 --
Weiß leider nicht wie ich die Datei hier Hochladen kann
8D0 907 558 E,,1.8L R4/5VT MOTR HS D02,
,Group A:,'001,,,,Group B:,'006,,,,Group C:,'007
,,RPM,Time,T.B. Angle,Ign. Timing,,RPM,Lambda,Lambda,Ign. Timing,,Lambda,Voltage,Duty Cycle,(no units)
,TIME,,,,,TIME,,,,,TIME,,,,
Marker,STAMP, /min, ms,°, °BTDC,STAMP, /min,%,%, °BTDC,STAMP,%, V, %,
,0.01,840,1.05,0.4,12.0,0.39,860,-0.8,4.7,12.0,0.81,8.6,0.145,5.9,0.93
,1.19,840,1.05,0.4,12.0,1.58,870,-0.8,6.3,12.0,2.03,7.8,0.430,5.9,0.93
,2.44,840,1.05,0.4,12.0,2.86,880,-0.8,6.3,12.0,3.26,8.6,0.085,9.0,0.93
,3.66,1440,2.00,8.7,26.3,4.08,1480,-1.6,7.0,27.0,4.49,3.9,0.765,13.3,0.97
,4.89,1200,2.30,9.5,24.0,5.28,1120,-0.8,2.3,21.8,5.79,0.0,0.695,8.2,0.98
,6.16,1000,0.90,0.4,12.0,6.56,930,-1.6,2.3,12.0,6.95,3.9,0.080,2.7,0.98
,7.36,800,1.05,0.4,12.0,7.78,840,0.0,3.1,12.0,8.16,1.6,0.780,3.5,0.98
,8.61,840,1.10,0.9,12.0,9.02,840,0.0,1.6,3.8,9.41,-0.8,0.840,14.1,0.98
,9.81,1400,2.20,10.4,26.3,10.21,1150,0.0,-1.6,22.5,10.61,-0.8,0.725,14.1,0.98
,11.05,1240,1.15,0.0,18.0,11.45,1090,4.7,0.8,13.5,11.83,2.3,0.070,6.6,0.98
,12.23,1240,0.85,0.0,18.0,12.63,1080,0.0,-1.6,13.5,13.17,2.3,0.085,3.5,0.98
,13.56,840,0.95,0.4,12.0,13.95,790,0.8,0.0,12.0,14.35,-0.8,0.770,3.9,0.98
,14.75,840,1.20,0.9,12.0,15.15,870,1.6,-3.1,12.0,15.57,-4.7,0.630,3.9,0.98
,15.96,840,1.20,1.3,12.0,16.40,870,1.6,0.0,12.0,16.84,0.8,0.465,12.1,0.98
,17.27,1360,2.30,10.4,25.5,17.71,1080,0.0,0.0,21.0,18.15,-2.3,0.770,16.8,0.98
,18.54,1200,2.90,11.7,19.5,18.94,1390,-2.3,0.8,22.5,19.37,0.0,0.760,36.3,0.98
,19.79,1800,3.95,21.7,19.5,20.21,2170,-3.9,-2.3,18.8,20.61,-2.3,0.090,91.0,0.99
,21.00,3200,6.15,59.5,18.8,21.43,2550,-4.7,0.0,23.3,21.84,0.0,0.835,99.6,0.99
,22.24,5120,7.25,85.9,25.5,22.65,2550,-4.7,0.0,25.5,23.08,0.0,0.885,99.6,0.99
,23.50,6400,0.95,15.6,29.3,23.91,2550,-4.7,-6.3,37.5,24.31,-12.5,0.890,85.2,0.98
,24.71,4480,7.00,86.4,27.0,25.12,2550,-4.7,0.0,26.3,25.51,0.0,0.855,99.6,0.98
,25.96,5240,6.95,86.4,26.3,26.36,2550,-4.7,0.0,27.0,26.78,0.0,0.870,99.6,0.99
,27.21,5920,6.75,85.9,26.3,27.61,2550,-4.7,0.0,27.0,28.04,0.0,0.900,99.6,0.99
,28.42,6160,0.75,13.9,37.5,28.82,2550,-4.7,-1.6,37.5,29.23,-7.8,0.610,0.8,0.99
,29.68,5160,0.75,11.7,37.5,30.07,2550,-4.7,0.0,37.5,30.52,0.0,0.020,0.0,1.00
,30.92,3360,0.70,6.5,36.0,31.36,2550,-4.7,0.0,32.3,31.80,0.0,0.020,0.0,1.00
,32.24,1760,0.80,3.5,25.5,32.66,1320,8.6,0.0,6.8,33.08,0.0,0.085,0.4,0.98
,33.59,960,0.95,0.4,2.3,34.10,900,-0.8,-5.5,12.0,34.52,-6.3,0.695,0.0,0.98
,34.91,840,1.05,0.4,12.0,35.39,870,0.0,-3.1,12.0,35.79,-1.6,0.175,0.4,0.98
,36.30,840,1.05,0.4,12.0,36.68,860,0.0,-2.3,12.0,37.07,-1.6,0.125,0.4,0.97
,37.45,880,1.05,0.4,12.0,37.87,870,-0.8,-3.9,12.0,38.33,-2.3,0.375,0.8,0.96
,38.74,840,1.05,0.9,12.0,39.18,860,0.0,0.0,12.0,39.65,0.8,0.130,0.8,0.95
,40.04,840,1.05,0.4,12.0,40.47,860,0.0,3.1,12.0,40.91,3.9,0.110,1.2,0.94<br /><br />-- 29.12.2011 - 20:20 --<br /><br />Drehe Lamgsam mit meinen Wagen durch, der durch zug wird immer weniger
Grade eben auf der Autobahn mit Rückwind hat er grade mal 190kmh Geschaft.
Steuerzeiten habe ich Überprüft die Stimmen.
Er macht einen Ladedruck von 0.6 Bar.
Im Standgas -0,6Bar
Suv ist neu.
Habe auch mal am N75 den Stecker abgezogen hat sich nix geändert.
N75 Tacktet hat auch 28Ohm.
Ladesystem ist Dicht
Mir kommt es so vor ob ich nur 120Ps habe total träge ist er.
Ich meine das Problem mit dem Träge habe ich seitdem ich die Drosselklappe gereinigt hatte.
Vorher hatte er Starken Durchzug, nach der Reinigung wurde er träge
