How to open the "Schlüsselkopf" on a "Klappsc
Diskutiere How to open the "Schlüsselkopf" on a "Klappsc im Elektrik & Co. 3B / 3BG Forum im Bereich Passat 3B / 3BG ( B5 / B5.5 ); I have been looking at this site http://www.passatplus.de/arbeitshilfen/schluessel/index.htm and my key loks the same, but I dont manage to get...
  • How to open the "Schlüsselkopf" on a "Klappsc Beitrag #1
petter_j
I have been looking at this site http://www.passatplus.de/arbeitshilfen/schluessel/index.htm and my key loks the same, but I dont manage to get the two plastic parts from each other (I need to transfer the transponder from one key to an other). ..
  • How to open the "Schlüsselkopf" on a "Klappsc Beitrag #2
DerAhnungslose
First check if you have an oval or rectangular key panel. Is it more oval then you see a notch below the VW-logo else you find the notch under the flipped open key.
Use a slotted screwdriver that fits into this notch. Then turn slowly but with a decent amount of power. :mukkies:
If you don´t cant to much the key should easily split into two parts.
Good luck :top:
  • How to open the "Schlüsselkopf" on a "Klappsc Beitrag #3
petter_j
Thanks for the help, but my problem is not to get the remote part and the key part from each other, but to open the plastic where the key blade is so tht I can remove the WFS transponder
  • How to open the "Schlüsselkopf" on a "Klappsc Beitrag #4
DerAhnungslose
There is no need to open the part, wherer the keyblade is fixed. The part where the key panel is attached contains the remote unit. And this box can be opened very easily without any tools.
Hope I got it right now and we are talking about the same keys.
  • How to open the "Schlüsselkopf" on a "Klappsc Beitrag #5
Subzero
@der Ahnungslose, da hast du was falsch verstanden. Er möchte den Transponder tauschen und dazu muß er den Teil mit dem Schlüssel öffnen.
@petter, to open the part with the key and the transponder, remove the vw logo on the back, it's glued on. Under this the is a little screw. After removing this screw you can open the key-part
How to open the "Schlüsselkopf" on a "Klappsc - Ähnliche Themen
How to disassemble the side mirrors... ?: How do I disassemble the side mirrors from an ( 2004 ) 3BG side mirror ? I shall paint the covers in a different color and need to get them apart.
Passat(2002, diesel) 3BG KLIMA im Passat 3B(2000, diesel): Hello ! Recent, i buy and i want to install a Passat 3BG Climatronic into a 2000 Passat 3B with AC. Problem is that Climatronic units of 3BG are...
Retrofitting ESP to a an ASR-Equipped B5.: My project this winter is just as the title states, installing ESP into an ASR Passat. I have pretty much all of the information that I need, but...
IRÜ installed, and I have a problem.: I have successfully installed IRÜ in my Passat, it works great. I have one problem though, the IRÜ will not work unless I arm the alarm with the...
Car radio one DIN ; need help from France please.: Hello ! First of all, im really sorry to not be able to post my question in german. Im from France i dont speak your language, and my english is...
