Getriebe Unterfahrschutz / Transmission Cover Passat 3BG
Diskutiere Getriebe Unterfahrschutz / Transmission Cover Passat 3BG im Karosserie 3B / 3BG Forum im Bereich Passat 3B / 3BG ( B5 / B5.5 ); Sorry for posting in English in a German Forum but unfortunatelly my German writing is not as good as my English. A) The car is a Passat 1.8T...
  • Getriebe Unterfahrschutz / Transmission Cover Passat 3BG Beitrag #1
alfanikos
A) The car is a Passat 1.8T (2001) with manual gearbox.
I intend to install a rear sound deadener/gearbox Belly Pan (undercover schield) same as the one existing in the diesel model.
From the ETKA catalogue I can find 4 options for this part.
1. 8DO 863822 (TDI 4 CYL MANUAL GEARBOX)
2. 4BO 863 822G (TDI 4 CYL AUTO GEARBOX)
3. 4BO 863 822N (V6 6 CYL MANUAL GEARBOX)
4. 4BO 863 822N (V6 6 CYL AUTO GEARBOX)
The difference is that some covers from all above do have a rectangular opening somewhere in the middle to accommodate the transmission.
Here are the questions:
1. Has anyone fitted such a cover? How difficult is to install it?
2. Which is the correct part number I have to use?
3. Which of the above covers do not have an opening? I suspect the item no 1 but can someone confirm it by just looking under his car?
B) In case above can not be answered can someone sendt me a VIN (vehicle identification number) for a Passat TDI (with 1.9 Liter engine and manual Gearbox)) model 2001-2005.
I will use this number to extract from ETKA the belly Pan Part Number.
Thanks in advance.
Getriebe Unterfahrschutz / Transmission Cover Passat 3BG - Ähnliche Themen
gamma 5 blaupunkt usb: hello, i hope you don ' t mind in writing in english i don' t speak German and i hope you guys help me Could i have a gamma 5 by blaupunkt and i...
Retrofit Panel Below Steering Wheel with Storage?: I apologize that I do not speak German but you guys know far more about these cars than in the U.S. I have a Passat 3B that does not have the...
3BG Wagon hatch on 3B Wagon... ??: :) Hi ! What will I have to do to make a 3BG Wagon hatch fit on a 3B Wagon ? I'm aware of that the hatch itself is a direct fit, But what...
Passat(2002, diesel) 3BG KLIMA im Passat 3B(2000, diesel): Hello ! Recent, i buy and i want to install a Passat 3BG Climatronic into a 2000 Passat 3B with AC. Problem is that Climatronic units of 3BG are...
Kaputt getribe? (tiptronic 5): Hello my name is Robert and I´m from Sweden. I was hoping you could tell me whats wrong with my Passat -01 Tiptronic 5-gang gearbox. When I give...
