Motor & Co.
N75 Valve upgrade????
[QUOTE="cruiser, post: 251466, member: 291"] @B5Crazy the K-version was built in the good old RS2 from Audi. This car has 315hp and a K24/26 was the reactor :D . the K04 is too big for a quick spool under 2K U/min. Either you have to reprogramming your software and/or controll your A/F ratio. Has you check your A/F ?? Is it too lean in this area?? The K-version is really agressive in the lower and higher rpm. In the middle rpm it's more weakly than the J. The J is better in the higher rpm and the H is more agressive in the middle rpm but really weakly in the higher. The most drivers in this forum can better handle with the J, any other with the K. Marco [/QUOTE]
Motor & Co.
